Thread: buying a used heatpump
    Apr 2014
    Stony Brook, NY
    159
    Well, I know its a risk, but I am looking at a used hayward 110k btu heatpump. Its 2 years old. Its not hooked up, so I dont know for sure its working. I can get it for less than 25% of internet price. Thoughts????
    May 2013
    North East Ohio
    959
    Re: buying a used heatpump
    well if it works sounds like a deal....if not, you are out the $$ not much more I can add...sorry!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Watch out for the type of refrigerant it uses, if it is R-22 which is being discontinued for environmental reasons it could cost you an arm and a leg to recharge
    Apr 2014
    Stony Brook, NY
    159
    Its a newer unit using the newer refrigerant.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok, just checking as they are still selling models with R-22 or they were a few months ago even though it is on the way out
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    You better get a check to make sure it actually HAS refrigerant in it. Also, make sure the person selling can provide you some proof they actually own it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
