Results 1 to 7 of 7
Thread: Pool Math for Texas
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Pool Math for Texas
    So the targets are preset in the calculator. Since I don't know what part of the country these numbers are based on, should 100+ summers in Texas possibly have different targets? Texans speak up!!! Or anybody with hot weather and full sun. I would even except Okies opinions.
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Pool Math for Texas
    Other than CYA being towards the higher end, I don't think there'd be many differences.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    That's the magical, mystical, average pool but has proved itself in most situations. More Texas sun? Raise your cya over the "average" we recommend to reduce FC loss. All pools are slightly different and YMMV. Accurate testing and monitoring of ....YOUR....pool will tell you what it requires. Awful good starting point though.
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    I must be old, I had to google YMMV
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Reddogdan View Post
    Your Mileage May Vary - I think
    You're done SLAMing when:
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Yeppers
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I guess Im old too.
    Divin Dave,
