Results 1 to 9 of 9
Thread: Intermatic timer - dial popping out
    Jun 2014
    Burlington, Ontario
    59
    Question Intermatic timer - dial popping out
    I'm a newb to this whole pool owner thing so please be gentle
    My new house/pool came with a T104-70 Intermatic timer on the pump (a Hayward 1HP Superpump). The previous owner had no trippers on the timer so I guess he just turned it on/off manually. I've installed a couple of sets of trippers (two blocks of time) and I used the green "on" trippers and gold off trippers. The timer is functioning (mechanically speaking) - the dial does turn and the pump is turning on and off when the trippers contact the switch. But each time the pump is turned on and off, the dial gradually pops out such that it stops rotating and the trippers no longer toggle the switch. This can happen in as little as 2 or 3 on/off cycles. Pushing the dial back in will get it working again.
    I've asked google about this and haven't found a similar situation. Does anybody know why this is happening and if there is a simple solution? I'm considering just replacing the switch but it seems like there should be an easier (and less expensive solution). I've tried swapping out trippers to no avail...
    The switch should be no older than 2002 or 2003 based on the age of the other bits.
    Thanks in advance!
    Jan 2013
    Houston, TX
    1,079
    Re: Intermatic timer - dial popping out
    Sounds like the spring has gotten weak or the on off rocker needs a little grease. The spring is under the silver arrow that indicates current time. The on off rocker is under the yellow dial in the 6 o'clock position. I would start with a dab of triflow on the on off rocker under the dial (and work it in - switch back and forth a bunch of times). Then add a dab of grease, just a little dab.
    It goes without saying turn the electric off at the breaker first.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jun 2014
    Burlington, Ontario
    59
    Tri-flow eh? How did you know I was a cyclist?
    On a working timer, when you pull the dial out, does it move back in under the spring's force or do you typically have to push it in? Mine has to be pushed in. A bit of lube could solve this.
    Sounds like some good ideas. I'll give them a try.
    Thanks.
    Jan 2013
    Houston, TX
    1,079
    Moves back in under its own power.
    Funny I've been using tri flow so long I forgot it was a cycling shop thing.
    MTB, Road, or CX?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I think the front is spring loaded. Is the center bolt tight?
    You can get a replacement pretty cheap.
    http://www.ebay.com/itm/Intermatic-T...item3a9202e040
    or check for an auction
    http://www.ebay.com/sch/i.html?_from...c&LH_Auction=1
    Jun 2014
    Burlington, Ontario
    59
    Hmmmm... Spring appears to be missing. Oddly, I think I have a spare spring.
    Mostly road (kuota kharma with SRAM force) but also have full sus MTB and an older hardtail for towing our trailer.
    Jan 2013
    Houston, TX
    1,079
    A pair of qr springs would probably do the trick as well.
    Hmmm might actually only need one.
    Nice ride.
    Jun 2014
    Burlington, Ontario
    59
    Update... Put in a spring from another time that isn't in use and added some lube and it appears to be working. Thanks for pointing me in the right direction.
    As an added bonus, I also fixed the slight leak in my pump by replacing the seal. I'm much happier with my pool now.
    Apr 2011
    Murrieta, CA
    2,360
    Glad it's worked out for you.
