Thread: Pool Vacuum for skimmer?
    May 2014
    Lake Forest, IL
    53
    Hi Everyone - I installed a Hayward skimmer on my pool and it has the vacuum attachment. What do you recommend as a vacuum? I have an intex 16' by 48" deep pool.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Pool Vacuum for skimmer?
    Quote Originally Posted by The Diesel View Post
    We have the Hayward and the Intex deluxe maintanence kit works great with it. $39.99
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Oct 2012
    Houston, TX
    186
    I went to Leslie's and bought a vacuum hose, head and telescoping pole. I got tired of the flimsy Intex pole and accessories. Having a regular pole is nice because standard accessories fit it.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Here is the cheap intex pole that comes with the easy set pools beside the one that comes in the maintenance kit. The white one is a lot heavier duty.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Second for the deluxe maintenance kit... It fits...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
