Thread: added fountain to stock intex pool (with pic)
    Mar 2014
    Brockville, ON, Canada
    23
    Hi, I rigged up a removable fountain on my intex ultra frame pool. I haven't done any hard plumbing, but thought the kids would like a fountain. I used ABS and the blue adaptor to connect to the water return outlet. I didn't glue the blue piece to the ABS (but did do the rest of the connections), it seems to hold enough by just sticking it in. This also allows for a bit of adjustment and makes it easier to screw on. When you are done playing, just unscrew and remove.
    Here is a pic
    16' round Intex Ultra Frame, Sand filter, filled May 25, 2014
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: added fountain to stock intex pool (with pic)
    That's a great idea... Well done...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Casey's Avatar
    SW PA
    10,457
    Pretty cool and your water looks great too!
