Thread: DE maiking past filter into the pool
    Mar 2014
    Foothills of Central Ca
    22
    For the last few weeks, I keep finding DE in the pool. I dissembled the filter but I did not find any tears in the grids. For giggles, pony'd up the money and bought new grids anyway. I recharged the filter and guess what,.......I still have DE in the pool. What gives?
    Jan 2013
    Houston, TX
    1,079
    Re: DE maiking past filter into the pool
    are you premixing the DE in a bucket?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Mar 2014
    22
    Quote Originally Posted by karmabiker View Post
    Yes and I make sure to slooooooooowly only pour a little at a time so it doesn't shoot past the filter either. I'm stumped.
    There are a couple of different problems that can cause this. Torn grids is the most common cause. Still, there are several other possibilities. If there is a problem with the main valve it can allow DE to bypass the filter and get into the pool. Typically that would be caused by a bad spider gasket in a multi-position valve, though something more serious could be wrong with the main valve.
    There are also a couple of places inside the DE filter where DE can leak past. There are several o-rings that must be present in the correct position to seal things together. It is also possible for one of the pipes or the manifold to be cracked.
    Jul 2011
    Austin, TX
    61
    Do you have an attached spa? If it is at a higher level than the pool (typically with a spillover) it could also be the check valve. To test, once the pump stops, shut off the spa altogether. If de continues to emerge, it's not the valve.
    16,000g in-ground plaster pool, attached spa, BBB, DE Filter, SWG
