Results 1 to 16 of 16
Thread: Standard Vacuum with Intex Ultra Frame (How To)
    I looked for some ideas on using a regular vacuum with my intex ultra frame pool and didn't really come up with much that I could do without ordering parts online. So here is what I did and maybe it will help some of you too.
    I went to lowes and picked up the cheapest vacuum head, a 25' x 1 1/4 vacuum hose, and a couple PVC fittings. After that all I had to do was attach them together and my filter now powers my vacuum. I don't know what the PVC fittings are called but here is the pictures.
    After attaching the fitting to my inlet on the pool filter I just feed the air out of the vacuum hose and attach it to the PVC fitting. It works like a charm and I no longer have to deal with trying to scoop the small particles off the bottom of the pool with the skimmer net. The whole set-up including an extender pole cost me about $65.
    I hope this helps at least a couple people.
    Intex 14x48 Ultra Frame 4,600 Gal
    1,000 gph Intex cartridge filter
    TF-100
    Savannah, GA
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Standard Vacuum with Intex Ultra Frame (How To)
    Thank you, was wondering if it were possible. Is there anything identifying on the label that says what it is that goes on the inlet? I had been considering trying to dimantle my over the side skimmer to use for a vacuum. Glad I won't have to.
    The receipt says it a 1 1/2" PVC union. I just looked for something about the right size while I was there and didn't think to look at what it was called... Sorry about that.
    TF-100
    Savannah, GA
    Mar 2014
    Brockville, ON, Canada
    23
    That looks like a good part to have found that screws on the inlet properly. I already got the blue one from Intex and am using it it with an old vacuum hose and head from a summer escapes pool. My question is, how do you keep the big pieces of debris from falling back into the pool when you disconnect the vacuum from the inlet?
    16' round Intex Ultra Frame, Sand filter, filled May 25, 2014
    Everything I vacuum goes into the filter. The biggest thing I have in the pool at anytime is a blade of grass. Those get stuck on the screen to the inlet but the filter is still running so they stay there until I can pick them out.
    TF-100
    Savannah, GA
    Mar 2014
    23
    That makes sense, thanks. I have only vacuumed once so far, but I think I shut off the pump before removing vacuum which was my mistake.
    Jun 2012
    Central Alabama
    55
    I have the same hose and vacuum head but all I do is unscrew the blue over the wall skimmer adapter and stick one end of the vacuum hose directly into the pool intake after I use the return to fill the hose up with water. I only have a 16x48 so I can easily get the entire surface without pulling the hose out of the intake.
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Names of fittings added
    Quote Originally Posted by RonW84 View Post
    Union (centre) and barbed adaptor (lower right)
    Union - disassembled
    Barbed adaptor
    Thanks for that abigail!!!
    TF-100
    Savannah, GA
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I have a ton of the orange fluffy things from our pine trees. Hoping to get the stuff today, and start vaccuuming tonight. I might vaccuum to waste as to jot make a mess of the filter. We have had a lot of rain the past week, it wont hurt.
    I only have the 1,000 gpm standard pump. Does it work for this?
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Jun 2012
    Central Alabama
    55
    Quote Originally Posted by Wraenking View Post
    I had that pump and I couldn't get it to work. I upgraded to the Intex sand filter and it's been great for filtering and to vacuum.
    Intex Ultra 16x48
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I couldn't get the union to thread on very far... Did you have any trouble?. Also, my local Lowes did not have the barb adapter in stock. Traveling tomorrow, hope to find one there.
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Nice find, is your inlet the standard intex inlet? This is the fittings I have. Hope it works.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Jun 2014
    Freeport IL
    46
    Question: If I have visible sand on the bottom of my pool, wouldn't that clog my filter? I have 18'X48" Intex Ultra Pool, very new pool owner! Have the cartridge filter A. Thought I would need self-contained vacuum to get this off bottom. Also bottom very bumpy, poor landscaper used sand under pool. Suggestions? Thanks
    Yes I can get it to work but I have to move slowly.
    Quote Originally Posted by PAGirl
    Mine fits fine.
    Quote Originally Posted by Jabo
    I have the same "type A" filter but I clean my filter after I vacuum... so no it does not clog it
    My pump is not very strong so I have to move slowly but I have figured out that if i get in the pool and put my goggles on and use the hose without the vacuum head like a shop-vac I can get every grain of sand off the bottom. I would imagine the bigger sand filter would make a huge difference but Im not upgrading unit next season.
    TF-100
    Savannah, GA
