Results 1 to 8 of 8
Thread: Daily Duties
    Daily Duties
    Good afternoon everyone,
    So i finished my shocking, pool is great beside the birds that keep pooping in it.. So now the game is to keep my chlorine levels up according to the charts, keep the pool clean and scrub once a week. Is that it? Should I shock once a week? Or as long as my level are good the pool is good? Please bare with me first year just using liquid chlorine and I want to make sure I am doing it right.
    Please and thank you
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Daily Duties
    Did you complete the SLAM process on your pool? I saw you had another thread on here where that is detailed/started.
    You need to pass the three SLAM criteria before going into "maintenance" mode.
    1. CC is 0.5 or less.
    2. OCLT <1 FC
    3. Water is crystal clear.
    Once you've passed those three, then you can go into normal daily maintenance of keeping the appropriate level of FC for your current CYA level. See the chart here: Chlorine - CYA Chart. If you always keep FC in the proper range, you should never have to shock/SLAM again.
    Isolated Spa - 345 Gallons
    Re: Daily Duties
    Yes the slam is completed. That must have been an old thread from last year.
    Awesome I didn't realize it was so easy.
    thank you
    Feb 2014
    Central Minnesota
    5,080
    Re: Daily Duties
    Quote Originally Posted by joe111 View Post
    thank you
    Yep, just realized that thread of yours was old. Keep that FC and you're golden. Cheers!
    May 2014
    Turlock, CA
    55
    Re: Daily Duties
    Most ongoing maintenance is weekly, but you should be checking TC and pH daily and adjusting accordingly. Only takes a couple of minutes.
    Once you get to know your pools appetite really well, you may be able to back off to every other day.
    21K gallon, plaster, 1hp Hayward MaxFlo pump, Hayward 244s sand filter, 3/4 hp Halcyon PB4-60Q booster pump, Polaris 280 cleaner.
    Re: Daily Duties
    Quote Originally Posted by rterickson View Post
    Or test every other day and add the normal amount on the other days without testing. You will need to keep records for it is to easy to mesa up this way. ..oh, today is Saturday? Guess l missed Thursday somehow.
    Casey's Avatar
    SW PA
    10,461
    Re: Daily Duties
    Check and dose daily and you should never have to SLAM the pool until you close it to get through winter mode. I sweep and brush once a week.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Daily Duties
    Welcome to the forum!
    Once you are on track with consistent FC levels there will be no need to shock weekly. One of the great pool store myths.
    Essential Links:
