Thread: Water temp above ground vs in ground
    Jun 2012
    Central Alabama
    55
    Can anyone explain how our above ground Intex in full sun all day is on average 8-10 degrees colder than neighbors in ground that only receives partial sun?
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
    Casey's Avatar
    SW PA
    10,461
    Re: Water temp above ground vs in ground
    They have solar? Running a heater?
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Over night temperatures will have a greater impact on an AGP vs IGP. The ground tends to hold heat, while the air temp can swing dramatically, which to an exposed AGP means temp drops that are much more noticeable.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    May 2014
    Lake Forest, IL
    53
    Quote Originally Posted by elwood58 View Post
    Is this really true though? Isnt the ground temp in the summer cooler than the air and in the winter warmer than the air in general? Down below the freeze line I dont think the temp varies much. Probably down in the 40s. I would think an inground pool would always be battling the ground temp.
    I would think the inground must have a heater.
    Jun 2012
    Central Alabama
    55
    No solar no heater. Standard in ground L shape pool. My thinking was the same as Diesel, hence why my labs won't stop digging in the corners of my house to lay in the cooler dirt.
    Intex Ultra 16x48
