Thread: Low pH during SLAM. Do I try to fix or just ride it out?
    Apr 2013
    Sandersville, GA
    4
    FC 16
    CC <0.5
    pH 7.3
    TA 50
    CH 100
    CYA 40 -50
    I have been in SLAM mode for 14 days. pH was super high (8+) before beginning SLAM. Used Pool Math to calculate muratic acid to bring it within range, but it apparently dropped the bottom out! At this point I have a (white) cloudy pool that seems to be making barely perceptible progress. Wonder if I should try to raise the pH or just keep on keeping on with what I am doing? Any advice would be appreciated. I have fought my way from here to clear before, but would really like to do it the most efficient way!
    27k (18x37 Grecian) IG vinyl
    SWG/Sand filter/1.5 hp high flow pump (gpm ?)
    Taylor k-2006 test kit
    Casey's Avatar
    SW PA
    10,457
    Re: Low pH during SLAM. Do I try to fix or just ride it out?
    Leave it alone while SLAM'ing and adjust it when completed if need be.
    Apr 2013
    Sandersville, GA
    4
    Thank you for your reply. That is what I figured, but needed some reassurance
    Jan 2013
    Houston, TX
    1,079
    Never mind. need more coffee.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
