Thread: Pentair IC40 to Run 24/7 or place it on a timer
    Question Pentair IC40 to Run 24/7 or place it on a timer
    Ok here's a question. I'm having to replace my current SWG (aquarite) and i'm looking at the IC40.
    1. My question(s) is do SWG need to run 24/7 (i'm currently running mine like that 24/7) I never turn that or my pump off they both run 365 (I live in Charleston SC).
    2. if i don't have to run the SWG 24/7 how do i determine how many hours I need to have it running and when is it best to run it morning, day or over night?
    3. can the IC40 be placed on a timer by itself or do i need to just manually turn it off, since we like to keep the pump going 24/7 to keep the water moving.
    I know a lot of questions hit me with any question for more info. thanks in advance.
    Infinity Trilogy pool 14 X 32
    Pentair Filter with Cartridges
    1 hp Hayward variable speed pump
    mineral springs SWG
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Pentair IC40 to Run 24/7 or place it on a timer
    If you intend to run the pump 24/7, adjust the IC-40 to a low percentage and see how it does.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    If you have a Pentair automation system you will be able to set the percentage setting on the SWG by steps of 1%, and that should take care of it.
    If you don't have a Pentair automation system, you are limited to setting the SWG by steps of 20%, which is a major disadvantage. You could compensate for that by using a timer, but you would be much better off getting a different brand of SWG that allows fine percentage control without an automation system.
