Thread: Filter Head Loss
    Jun 2014
    Bellingham, WA
    6
    Filter Head Loss
    I have a Pentair Sand Dollar SD60 sand filter. My pump died so I'm trying to size a new one but I can't figure out what the head loss from the filter is. Can anyone help me?
    Thanks!
    Dana
    18,000 gal above ground vinyl
    Pentair Sand Dollar SD60 sand filter - 60gpm - 2.3sqft
    38,262
    Re: Filter Head Loss
    Pump size is not really dependant on your filter size. Just get a 1 HP 2 speed pump, or replace the motor on your existing pump.
    Jun 2014
    Bellingham, WA
    6
    Thanks, jblizzle.
    How do I ensure that the pump won't run at a higher flow rate (60gmp) than the filter is rated for? The pumps I've looked at list flow rate as a function of head, which I was assuming was mostly related to the filter. The plumbing must factor in, too, but we don't have long runs. It's 1.5" plumbing.
    38,262
    Calculating head loss is not very easy. Just get the smallest 2 speed pump you can find and you will not have a problem.
    Many members use the 1hp matrix power flo.
    Jun 2014
    Bellingham, WA
    6
    Thanks a lot, Jason! I'll give it a shot.
