Results 1 to 13 of 13
Thread: Reading the calculator
    Jun 2014
    Atlanta, ga
    26
    My pool is cloudy. I don't even know where to start. It looks like i have no chlorine. What do I need to do with the readings below?
    FC - free chlorine 0 ppm
    CC = Combined Chloramines 0
    TC= total chlorine 0
    PH 7.2
    TA - Total alkalinty 110
    CH - calcium hardness 150 ppm
    CYA - 100
    18K gal, IG Gunite, Sand Filter, TF-100 test kit
    38,303
    Re: Reading the calculator
    What test kit are you using?
    Jun 2014
    Atlanta, ga
    26
    The TF100
    38,303
    Likely the first step should be replacing water to lower the CYA to a manageable level. But you need to be careful how much you drain depending on ground water levels.
    Then get some chlorine in the pool. What does the water look like?
    Jun 2014
    Atlanta, ga
    26
    I understand that part. I just drained half and re-filled it because CYA was like 140. What would be the next step? Just curious
    Jun 2014
    Atlanta, ga
    26
    Can I not drain the pool and balance the other levels? Ill drain it in a couple of weeks. I just don't want to deal with it right now.
    38,303
    If clear, you need to maintain the FC above 7ppm all times.
    If not clear, you need to SLAM at a FC of 39ppm.
    Jun 2014
    Atlanta, ga
    26
    It's really cloudy. I guess Ill SLAM?
    38,303
    Are you sure the CYA is not above 100? Trying to SLAM with the CYA that high is not a good idea.
    Jun 2014
    Atlanta, ga
    26
    I'm pretty sure cya is around 100 to maybe 90. I would just hate to drain the pool again. I'm going on vacation tomorrow for a week.
    38,303
    Well then there is no point on doing anything. You can not SLAM the pool in a day. Start over when you get back.
    Jun 2014
    Atlanta, ga
    26
    Ok. Thanks for your help.
    38,303
    Although your CH is too low and could with the low pH, is not good for your plaster.
