Results 1 to 14 of 14
Thread: pool heater piping question
    cobrahd1999's Avatar
    Jun 2014
    Manteno/Illinois
    9
    Question pool heater piping question
    I just bought my 1st pool heater for my above ground pool. the heater has 2" pipe my pool is 1-1/2" pipe can I reduce the 2" to use my 1-1/2" and also do I need a water flow meter and a check valve. I hope all this makes sense. lol
    Have a great day Frank
    Disabled Vietnam Vet 68-69 US ARMY Brothers Forever..
    "The trouble with the Vietnam War it killed so many that survived"
    "That's all I have to say about that. "( Forrest Gump)
    Retired Carpenter Local 199& 272 Chicago
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: pool heater piping question
    You can use reducers, no problem.
    I would think the flow meter and check valve are options that you can but don't absolutely need to install.
    Jun 2014
    Manteno/Illinois
    9
    Charlie thanks about the water meter and check valve that's one less expense lol. Do you happen to know any thing about the plumbing if I need to run as much as possible 2" or can just connect to the 1-1/2" pipe I already did? Have a nice weekend.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    If you main pool plumbing is already 1-1/2", no need to do anything else. Just use the same size pipe.
    May 2014
    Lake Forest, IL
    53
    I reduced from 2" to 1.5". Didnt use a meter or checkvalve on heater just before the pump. There are pictures of my install in this thread:
    http://www.troublefreepool.com/threa...for-intex-pool
    Brian
    Here is a picture:
    Intex Ultra Frame 16' by 48" deep - Pentair Superflo 1.5 HP pump with sand filter, Hayward H150 Heater, Hayward Skimmer and 2nd return
    Jun 2014
    Manteno/Illinois
    9
    Looks good and thanks guys for the pix I hope to start on my install on Saturday. All my stuff is close to the pool 16' from the house and 6' from the pool. Its a Hayward H200FD just finished reversing everything from right to left. Hardest part is now the digging for the gas line have to be careful have sprinkler system. lol
    Jun 2014
    Manteno/Illinois
    9
    Forgot to ask should I put in a by pass if I don't need the heater or just turn the heater off just let the water run threw the heater?
    May 2014
    Lake Forest, IL
    53
    I just let water go through heater
    Jun 2014
    Manteno/Illinois
    9
    Diesel thanks now that's less piping . I see you live up north Bears use to train up there now spring camp is out my way. lol I only been out here since 07 a complete different pace then I was use to now in farm land lol.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Quote Originally Posted by cobrahd1999 View Post
    100% of my water runs through my heater. It just doesn't get heated 99% of the time.
    May 2014
    Lake Forest, IL
    53
    Hey cobra - Halas hall is still here. this is where bears practice during season. They used to practice in Platville, WI. Now down in Bourbonnais.
    I wish I had to heat my water as much as richard!!! So far I am heating water 99% of time we use pool. Need warmer weather!!!
    Jun 2014
    Manteno/Illinois
    9
    Here is some pix of my pool heater nightmare to a plumber. Small Pool Heater Hookup 6-29-30_1.jpgSmall Pool Heater Hookup 6-29-30_2.jpg Small Pool Heater Hookup 6-29-30_3.jpg here is the 1st 3
    Jun 2014
    Manteno/Illinois
    9
    here are the last 3. [IMG] [IMG] [IMG][/IMG]
    poolsam's Avatar
    Jun 2014
    Bangor, maine
    66
    I just plumbed a Hayward 100K BTU for intex 16 foot metal frame. I used 1 1/2 inch pipe. Buy a 2 inch male NPT to 1 1/2 inch PVC on either side. I then glued a union so I can easily remove pipes from heater if needed. I elected to plumb a heater bypass T on with side with three ball valves (bypass, heater inflow/outflow after bypass). Having done so, I let water run through heater 100% of time and heat as needed.
