Results 1 to 11 of 11
Thread: Want to Test Total Hardness in home water supply
    Jun 2008
    Near Tampa Florida
    17
    For the sake of calibrating my water softener I am trying to test the Total Hardness of the water coming to my home. I have read that the standard Calcium Hardness test uses of R-0010 (Sodium Hydroxide) as a base/buffer is to avoid interference with Magnesium. As I understand it at high pH the Magnesium will precipitate out. In order to measure Total (Calcium + Magnesium) Hardness can I simply not use R-0010 leaving the pH at about 7.5 and the Magnesium in solution?
    Mike
    10K Gal IG Plaster, 1 HP Pentair WhisperFlo Pump, 100 sq ft Pentair Clean & Clear Cartridge Filter, AquaRite SWG, Paramount PCC2000 pop-up cleaner, Rheem/Raypak 266 heater, TF-100 Test Kit, SpeedStir
    Re: Want to Test Total Hardness in home water supply
    I can't help with the chemistry but you might get those answers from the water company. Our water district posts the annual water test online and I think it may have those values. A phone call to that office might help you otherwise.
    Jun 2008
    Near Tampa Florida
    17
    Thanks anonapersona. I spoke to our local water utility office and they were no help. They said they don't measure hardness and don't need to report it. If I want to know what the Total Hardness is they said I should buy a test kit and measure it.
    Mike
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    This sounds like a question for Chem geek! I'll get the signal set up!
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    According to the instructions in the Taylor K-1722 that tests for Total Hardness as well as Calcium Hardness, it doesn't appear to be as simple as just not adding the R-0010 Calcium Buffer (sodium hydroxide). Instead of the R-0011L (triethanolamine 77%, isopropyl alcohol 23%, Calcon < 1%), they use the R-0854 instead (same ingredients except instead of Calcon it says a different chemical). I think they use a different though related dye. I suspect that you'd get an approximate reading of Total Hardness by skipping calcium buffer step, but it might not be as accurate as using the real test for Total Hardness. You could try it on tap water with known Total Hardness from your water quality report and see what happens.
    Jun 2008
    Near Tampa Florida
    17
    Thanks Chem Geek!
    Jul 2013
    western new york
    62
    Quote Originally Posted by mikemctx View Post
    Mike
    wonder if this may help you out: http://www.bulkreefsupply.com/calciu...jFWY1mMs_D_BwE
    15k gal inground Viking fiberglass pool; Hayward Variable 1.5hp pump (Maxflo VS); Hayward swimclear 325 sg ft cartridge filter; Raypak 206A 199k btu nat gas heater; Aquabot Bravo robotic pool cleaner
    Jun 2008
    Near Tampa Florida
    17
    Thanks all. I'm good at this point. Talked to my water softener installer (who I trust and has been servicing my area for decades) and he confirmed that there is virtually no magnesium in our water supply. Thus by measuring Calcium Hardness I'm effectively also measuring Total Hardness.
    Mike
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    In most cases, it will get you more than close enough. Check with your guy, but it should be making soft water to the quality of 3 grains or less, all the way to the end of the run. That conversion to PPM is 17.1
    So if you have 3 GPG (grains per gallon) it will be 51.3 PPM.
    It's a great idea to monitor your softener for sure. Somewhere on it's display, it should show you gallons remaining. When it regens, this starts over. Lets just say yours can process 450 gallons after regen. You would want to check it as close to zero gallons remaining to really understand how well it is doing. You should be just as soft here as you were on the front end. If not, contact your guy and let him know you are leaking hardness on the end of the run.
    Essential Links:
    Jun 2013
    East TN
    309
    We have hard water here and have to clean out the water heater about every year because the heat makes the calcium settle in the tank. Once the calcium gets to the bottom heating unit it will burn it out. Your water heater will eventually tell you if your water softener is working good or not is what Im trying to say here.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    If you don't mind spending a little money, the Hatch 5b kit is pretty much the standard for home water hardness testing. Bought the kit back when I was trying to properly size my whole water softening system. The kit pretty much backed up the numbers I already got from my water company.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
