Thread: Brown oil from light fixture
    May 2014
    Lake Jackson, Texas ( Houston)
    10
    I am draining my pool for CYA and CH reasons, and a brown oil oooze came out of the bottom of the light fixture. It is not water soluble . Gunite Pool built in 85
    Problem??
    20,000 gallons in-ground, plaster, built in '85
    Sand filter specs TBD
    Pump info TBD
    Solar Breeze skimmer, TF100
    Jan 2013
    Houston, TX
    1,079
    Re: Brown oil from light fixture
    Problem.
    Can you pull the fixture to see if it is coming from inside the housing or from the niche?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    May 2014
    10
    I'll try in a bit after I take the rental pump back. Thanks
    Pump info TBD
    May 2014
    10
    Just some brown slime that had collected in the fixture. Thanks
    Pump info TBD
    Algae perhaps
    18' x 36' saltwater inground vinyl pool
    Jan 2013
    Houston, TX
    1,079
    Inside as in udder the glass? Or between the fixture and the niche?
    Pictures would be helpful.
