Results 1 to 15 of 15
Thread: CYA TF100 Test and getting CYA up
    I really don't like the disappearing dot. Is there not a cheaper more accurate method using drops of something like the other tests? last week or week before i seem to have tested CYA at about 40, added what should have brought up to 60 about 4 or 5 days ago. we have had a lot of rain, brought pool up from mid skimmer to just a hair over. now it tests at 30 or below.
    Located in Ottawa, Ontario Canada
    23K Gal, AG, Cart filter, 1.5hp 2speed hay PowerFlo Matrix, Install Sum'13, Aquatrol SWG, Solarbear panels, kreepy Krauly E-Z Vac, TF-100
    Artesian ~500gal Grand Gayman Island Spa
    38,237
    Re: CYA TF100 Test and getting CYA up
    That is the best test that exists for CYA.
    You need to be consistent with the lighting as that affects the reading. If you are unsure, buy some of the standard solution and figure out what lighting and test method works for you: http://tftestkits.net/images/products/605.JPG
    Oh, but you are in Canada so not sure if you can get it from there.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    AFAIK the disappearing dot test (melamine ?) is the cheapest & most accurate test available. Sometimes the state of the art is dismal
    Have you run the pump a lot since the rain ? If not then you may have a layer of water on top with relatively lower concentrations of everything as a result of the rain. Also CYA might not all have dissolved in 4-5 days, general recommendation seems to be "wait a week before testing".
    I haven't found an easy way to get TFT products up here, but the Taylor K-2006 (which you can get up here, and which I have) uses exactly the same test with the same reagent.
    The local Taylor retailer ( http://piscines-apollo.com/cubecart/ ) doesn't seem to carry the standard solutions though.
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Donldson's Avatar
    NW Ohio
    2,880
    This question gets asked a couple times each season, and i completely understand. It has a fairly good user margin of error, which can be a real pain in the backside. I am positive, however, that if an accurate drop based version existed, Dave would have it in the TF-100.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    38,237
    Quote Originally Posted by Donldson View Post
    Sent from my HTC Thunderbolt.
    He is trying to find something. There is a different CYA test that uses tablets instead of the liquid reagent (although you still look in the tube), but he does not feel like he gets consistent accurate results with it. Too bad as the tablets would be a lot cheaper to ship than the big bottle of liquid.
    I'm almost afraid to ask this question.
    How do the pool stores test for it?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by outdoor View Post
    My guess is http://www.randomnumbergenerator.com/
    Isolated Spa - 345 Gallons
    38,237
    Some use the dot test, some likely use a test strip. They are horribly bad at it though ... reporting 40ppm when it is 340ppm or reporting 40ppm on tap water which is 0ppm. Those are 2 actual examples.
    Jun 2011
    New Jersey
    149
    I am in the same boat been trying to do the test for couple of seasons and I feel like I have not gotten a good reading yet..... it seems no matter how much stabilizer I add the actual CYA level in my pool stays at the same number (rising slightly) nothing to what the numbers actually suggest it should jump too. I think I just don't know how to read it but as long as pool stays clear I cannot worry about it anymore cuz I would be dumping hundreds of lbs of stabilizer :P
    Free Form Gunite Saltwater Pool, 29,000 Gallons, Jandy DEL60 Filter, Jandy AquaPure 1400 Chlorinator, Polaris 380 Cleaner, Attached HotTub.
    38,237
    Jun 2014
    Alexandria Virginia
    18
    I've used up almost all of the CYA test solution in my Taylor kit. All other bottles are quite full. Can I buy a large bottle of CYA test solution as a stand-alone purchase? If so, please suggest a vendor.
    Thanks.
    bridgman's Avatar
    Mar 2014
    461
    http://tftestkits.net/R-0013-CYA-Refill-8-0z-p52.html
    My local Taylor dealer ("local" means 300 miles away up here) has 0.75 oz and 2 oz bottles, but tftestkits has 8 oz bottles for a good price. It's probably possible to get larger bottles from Taylor as well but tftestkits sells the same reagents in the right sizes for TFPC.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    See what other refills you might need and save shipping by ordering it all now. A speedstir makes a wonderful Father's Day gift for yourself.
    bridgman's Avatar
    Mar 2014
    461
    For once in my miserable life I posted faster than Richard
    EDIT - never mind, you were replying to my post
    May 2014
    Phoenix, AZ
    34
    I got a 16oz bottle from Amazon.
    i would rather buy from TFTestkits.net but they do not offer the bigger refill sizes.
    25K gal, fiberglass, Hayward 1hp pump, Sta-rite 30" sand filter, Hayward Pool Vac
