Results 1 to 7 of 7
Thread: upright supports under ledge missing
    Jun 2014
    belleville/nj
    3
    Just had an Impress 15 x 30 pool installed and noticed not all uprights have the top support bracket, does this seem correct. See picture attached, left rail has it right doesn't. Missing 8 in total and ledge is "floaty" where they are missingpool.jpg
    Casey's Avatar
    SW PA
    10,461
    Re: upright supports under ledge missing
    Did you install or have it professionally installed? Regardless, I'd call whoever you purchased from and see if they can ship you the parts or replace the missing ones.
    Welcome to TFP!
    Jun 2014
    belleville/nj
    3
    Talked to installer. He said the pool only comes with brackets for uprights on rounded section of pool and not straight portions (oval pool). He said he has installed a lot of these impress ovals and that's all they send. He is an honest guy and there were no extra parts lying around. There are screw holes in the rails to accept something.
    So you agree they should be there?
    May 2014
    SW, MO
    58
    Can you pull up some pics of it from the manufacturer website or even in google pics to see what others have. We've been doing a lot of pool shopping lately. Looked at one almost identical to yours yesterday and I remember them being on every one but it was a small 8' round floor model so maybe that is why.
    Casey's Avatar
    SW PA
    10,461
    I would think that they should all have the same hardware. It's hard to say though. Do all the post have holes to accept the hardware?
    Jun 2014
    belleville/nj
    3
    The pictures I have seen seem to have them on all uprights. Called manufacturer, (Celebration) waiting on an answer.
    All uprights have holes. Ledge is just not as strong where they are missing.
    May 2014
    SW, MO
    58
    Looking here http://www.poolworldinc.com/wp-conte...s-Brochure.pdf it shows them on each one, an the description says they are fully supported uprights with a clear photo of a panel having one on each side of it. Pretty sure you are missing your supports. Of course you can only clearly see the round pool totally, not the oval sides.
