Thread: Replacing my cleaner
    Apr 2014
    Louisiana
    51
    Hi guys
    I had this pool cleaner
    http://www.epoolshop.com/hayward_pha...l_cleaner.aspx
    I hated it and just pulled it out and gave up on it. Now someone has given me this used pool cleaner
    http://www.polarispool.com/Pressure/Polaris-165.aspx
    Will I be able to use this cleaner with the same pump?
    The end of the old cleaner broke off in the jet were it attachs to the pool. I was able to unscrew it from the pool wall. Now i have a piece which has threading like a screw (end that goes into the pool wall) with a piece broken, but still inside of it. It has a rubber seal and I can't seem to get the thing loose. The end of the Polaris 165 has threading but it's not like a screw. My question is: are these pieces uniform? can i buy another piece to screw into the pool wall to attach the cleaner? if so, what is this part called?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Apr 2014
    Louisiana
    51
    Re: Replacing my cleaner
    I"m sorry if this is hard to follow. That's kind of my problem, I can't google this. The question is basically: is the part that attaches to the pool wall the uniform? if so, what is it called and where can i get one? if not, what can i do?
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    38,295
    Go the link you provided for the new cleaner. Click the downloads tab. Open the Manual. Diagram with part name and numbers on page 8/9.
    Apr 2014
    Louisiana
    51
    you think it's this?
    27 6-502-00 ZZOD5208 Polaris Universal Wall Fitting Quick Disconnect for Polaris Vac-Sweep 60, 65, 160, 165 and Turbo Turtle Pool Cleaners
    http://www.poolcenter.com/p/vac-sweep-165
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Apr 2014
    Louisiana
    51
    I already have this piece
    http://www.amazon.com/Zodiac-6-502-0.../dp/B004VU8U3E
    THis looks like what maybe i need but looks a little different than mine
    http://www.amazon.com/Zodiac-6-500-0...KN5MZ5FK4PYKT6
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
    Apr 2014
    Louisiana
    51
    I guess i needed to talk it through. I got what I need, thanks for the help!
    30,000
    IG (in ground)
    vinyl
    sand filter
    SWG
