Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Better and bigger ladder for bigger people?
    Jun 2014
    Port St Lucie
    2
    Hi, my family and I bought a Intex 22f x 52 in last week. After being a little difficult to set up, we finally have it up and running...mostly. However we are experiencing a problem with the ladder that we did not foresee and now half of family can't use the pool. We thought we would have trouble with the A style ladder because of the weight limit but really we are having trouble with the size of the top step. The top step is very tiny and because the ladder is unstable, me and my mother can not get in. My little brother who is a healthy size 6-foot 16 year old even has trouble with the top step being small. Are there other ladders that have a bigger top step? I have been googling for different ladders but they all look to be the same and I can't build a deck or get anything expensive. Any help would be greatly appreciated.
    Casey's Avatar
    SW PA
    10,428
    Re: Better and bigger ladder for bigger people?
    Are you looking for steps or a newer ladder/A-Frame?
    Jun 2014
    Port St Lucie
    2
    An ladder frame. From what I have seen of steps they cost to much.
    May 2013
    Janesville WI
    74
    We just upgraded to the Confer A-Frame pool ladder and couldn't be happier. Very sturdy and have no concerns about older people climbing and getting in. Well worth the money IMO. Quite a bit bigger then the one that came with the pool but it works wonderfully. Don't hesitate to but it, probably the best quality one out there.
    Intex 18x48/2650 Sand/56601E SWG
    rmax's Avatar
    Jun 2011
    Liberty, TX
    10
    We bought this ladder for our Intex. I have also included the link where you can read some reviews about it.
    http://www.amazon.com/Confer-Plastic...2662537&sr=1-1
    19,000 Gallon 12' x 32' Fiberglass Pool
    Hayward 24" Pro Series S244T Sand Filter with ZeoBrite sand, Hayward SP2602VSP SuperPump variable speed pump, Hayward Aqua Rite SWG,
    TFTestKit-100 with Speed Stir
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Here's a link to the ladder I'm getting...
    http://www.ebay.com.au/itm/400687317...84.m1423.l2649
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Orlando, FL
    690
    Try Craigslist, people sell better ladders all the time.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Are you sure you can't build something like this?
    This was the first stage in the pool deck I'm putting together in small sections. Hand rail wasn't hard to add.
    If you want, I'll guide you through building something similar.
    Do note, the 4x4 posts are not in the ground, they are just sitting on it. Easily moved if I need to take the pool down.
    The ladder is secured to the deck through holes drilled through the deck with a 2x4 underneath.
    Jul 2013
    New Jersey
    70
    Quote Originally Posted by Charlie_R View Post
    This is exactly what i'm looking to do. I sent you a PM, not sure if it went through. Can you offer any help with building something like this? You can send me PM... Thanks!!
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    We have an Integrity ladder with our Intex 18 x 9. Very sturdy.
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit - Swimmers: Twins (Boy/Girl) 16 yrs old
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Sent a PM with some instructions.
    Jun 2014
    West Richland
    4
    Hello Charlie R...can I get a PM with those instructions as well?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    To save a bit of typing to multiple people, I'm going to put it in here. Apparently the new software doesn't automatically save sent messages, so I couldn't copy/paste.....
    Cguzz, Welcome to TFP!
    I'll start with a basic parts list for one section. Understand that these are actually a "throw together" from material I had on hand from several other projects, and are designed for a seasonal pool that may be taken down over winter. Sized for Intex style pools, 48" high. Sorry I don't have pics to go along with the instructions. Designed to be movable, and can be expanded by building more of these sections then filling in the space between them.
    Parts:
    All lumber should be pressure treated, since it will be exposed to weather and pool water.
    2 4x4 8 ft
    6 2x4 8 ft -- warning, you may need more or less of these.
    6 5/4x6 8 ft deck flooring
    5 lb box of 3"x9 deck screws
    We will be putting this together in small steps, each building on the previous.
    Start by cutting the 4x4s in half, so you have 4 4 ft pieces. Cut 2 of the 2x4s in half, for 4 pieces 4 ft long.
    Screw one 2x4 to two posts, flush with the top of the 4x4, with the ends of the 2x4 flush with the sides of the 4x4s. The second 2x4 needs to be 6" up from the bottom of the 4x4s. Build two of these frames. These frames are sized for the length of 1 section of top tube of an Intex pool, and will be just a bit wider than the section of pool.
    Here is where you may need more 2x4s. Determine how far you want this deck to extend away from the pool, and cut 2x4s to that measurement. I have a space restriction so I just used 4 ft for these as well, but you could go longer if you want. Screw these to the frames you just built, making sure the top 2x4 is flush with the top of the 4x4 and the outside of the 2x4 you already have on the frame. Same with the bottom 2x4, same height as the others, and flush. Measure the inside to inside between the 2x4s you just added. You will be cutting 2x4s for internal joists to support the flooring. If you went with the 4 ft basic dimension for the distance from the pool, you'll need 2. If you went longer, you'll need 3 or four depending on how far you went. Maximum distance between joists is 19". All should be equal distance between any two flooring supports.
    Now you should be ready to add the actual floor to your deck section. You could use shorter screws, I find the 3" screws hold better. Two screws per joist in each flooring board.
    Move the completed section to your pool, and level it.
    For your ladder. If you have the tube frame ladder like mine, you can remove the legs from one side. Place the remaining side in the pool with the A frame loops sitting where you want them on the deck. Mark the placement, and note the angle that the loops have to the deck. Drill where you marked with a 1" hole saw at the angle you noted. Screw a 2x4 scrap to the underside of the deck to support the ends of the loops.
    As you can see, this system is sturdy, mobile when you need it to be, and easily expandable.
    I hope my instructions make sense to any who want to try this.
    Good luck!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    If you want to save the PMs you send, click on "Notifications" near the top right of any page. There will be a box called "my settings" on the left. Click on "general settings" and scroll through til you get to "Private Messaging". The last option should be "sent private messages". Click "Save a copy of sent private messages in my sent items folder by default" to turn on this setting.
    Love TFP? Become a
    TFP Supporter!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Thank you Zea3!
    Jun 2014
    West Richland
    4
    Charlie....Thanks for the welcome and the instructions!
    I am assuming that I can just bury and concrete the 4x4s to make it more permanent?
    Also, did you use the 2x4s to make the ladder?
    Thanks again!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Yes, you can make it permanent if you want.
    The ladder onto the platform is 2x4, but is a bit steep. I'll be making another one out of 2x8 sometime soon. I'll post pics and description as I build.
    You can browse through the album, there are a couple of close-up pics of the ladder.
    http://s1094.photobucket.com/user/bc...?sort=3&page=1
    Jun 2014
    West Richland
    4
    Thanks!!
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    I have the Confer A-Frame ladder, which is very sturdy - I wish it wasn't so high. I would rather that the height would be adjusted to the pool's actual size. I'm in my mid 60's and it is a bit of a climb and then I can see two yards over - and they can see me!
    16' x 48" 5000 gal. Intex Ultra Frame AG Pool, Los Angeles, CA
    Hayward Full-Flow Cartridge Filter System with 2 Speed Power-Flo Matrix Pump,
    Intex SWG, Intex Wall Mount Surface Skimmer, Solar cover & Solar Roller,
    Confer Plastics A-Frame 7200 Adjustable Roll-Guard Safety Ladder,
    Kokido SkoobaMax Vac, Custom Canine entry & exit ramps,
  20. Back To Top    #20
    Can you send some instructions this way also?
    13500 gallons
    Intex 2650 Sand filter pump
    AG
