Thread: Stabilizer
    Jun 2012
    Bolton Ontario Canada
    45
    Stabilizer
    Hey folks, I have a question.
    according to the Pool calculator, for my 80,000 litre pool:
    Each 200g puck of trichlor lowers PH by .12
    Each 200g puck of stabilizer lowers PH by .05
    I would have expected the opposite...by does stabilizer by itself have a smaller effect?
    THX!
    16x32 vinyl
    80,000L chlorine
    21" Hayward sand filter
    Re: Stabilizer
    Trichlor is a strong acid, while cyanuric acid is a weak acid. I'm not sure why you would expect anything different.
    Jun 2012
    45
    Re: Stabilizer
    Thanks, (and please forgive me!). I hadn't really considered that it was different acids. I thought trichlor was just a name for stabilized chlorine, using the same acid as would be in a stabilizer puck.
    I really don't use pucks much, and will soon be re-filling after my new liner is in. I thought about using Trichlor to get both FC and CYA, but I can see that's not really any easier if I have to manage PH as well.
    16x32 vinyl
    80,000L chlorine
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Stabilizer
    Trichlor reacts with water to break down into CYA and chlorine, it is not just CYA mixed in with something else
    Jun 2012
    45
    Re: Stabilizer
    Awesome, thanks for that info.
    16x32 vinyl
    80,000L chlorine
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Stabilizer
    Quote Originally Posted by Tie Twist View Post
    Give that man a gold star!
    It is much easier to juggle one ball than three, isn't it?
