Results 1 to 7 of 7
Thread: Stabilizer at bottom of pool
    Jul 2013
    Long Island, NY
    536
    After I added the stabilizer to my pool I read about the sock method which is genius. My question is can the CYA sitting at the bottom of my pool for the last 3 days like "burn" through the liner? Should I vacuum it up or will it eventually dissolve. This is probably a dumb question but that fact that it says acid in the name makes me nervous it will eat through my intex liner.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    38,540
    Re: Stabilizer at bottom of pool
    Vacuum it up or it may leave faded spots on your floor.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    It won't eat through the liner but it may leave freckles. Vacuum it up and let it dissolve in the filter. Hopefully, you won't need to clean the filter before it's done.
    Jul 2013
    Long Island, NY
    536
    I can put it in the cartridge filter pump?
    SWG: Intex CS8110
    30,432
    Yes. Vacuum it up sooner rather than later.
    Jul 2013
    Long Island, NY
    536
    wow I never knew you could put chemicals in there.
    SWG: Intex CS8110
    38,540
    Ideally you shouldn't, but that is the lesser of 2 evils in this case. Cheaper to replace a cartridge (although not likely) than your liner due to faded spots.
