Thread: Glycol based solar heating system
    Azmp1's Avatar
    Jul 2012
    Maryland
    284
    Getting some quotes before I decide to DIY the solar.... So I had one of the contractor come up and give me an estimate, I thought it was going to be a standard type solar, but turns out he only does closed loop glycol based system with glass/metal panels and metal piping, comes with its own circulating pump and the heater exchanger that's get plumbed into the system much like the regular heater would. The rest of the system is completely separate from the pool plumbing. Sounds expensive already, but nevertheless interesting. The guy says he does manly (and very many) of these systems for the home water heating, but also pools though not as much, but he claims that it works very well, if not better then the standard solar.
    I've never seen or heard of these systems. Does anyone here run this type of system or have experience with them and can comment?
    Thanks
    Alex
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Re: Glycol based solar heating system
    They aren't nearly as efficient for pool use as more conventional pool panels. However, they can partly make up for that by heating home water when you aren't using them for the pool. If your primary interest is in heating the pool they are not at all competitive with more conventional systems. They only make sense when you have limited roof space and really want home water heating as well as pool heating.
    Azmp1's Avatar
    Jul 2012
    Maryland
    284
    Good info, thank you Jason. I have a feeling the cost will be quite a bit more then conventional system as well.
