Thread: Pump Motor Fixed...Need Help
    Smile Pump Motor Fixed...Need Help
    Oh my has it been something this year. Our pump motor died in March, then a relative took ill and moved in with us taking most of our time and extra dollars. With that said, our once lovely 22,000 gallon pool is now a brown smelly swamp. We have been getting the debris out as we have seen it, but you can only imagine the state of our oasis!
    We got a new motor (finally) and installed it only to find quite a few leaks due to freezing over the winter. My husband fixed the leaks and we turned the pump on. UGH! He proceeded to backwash for what seemed like an eternity because we knew the sand filter was probably yucky.
    Our pool has never been like this and I really don't know what to do other than shock using the methods here.
    I know I need to continue to get all the debris out before putting in bleach or nothing will really work, right? Should I replace the sand in the sand filter before going any further? The sand was two years old this spring. I need to get a new PSI gauge as this one is shot.
    Then do I just continue the shock process until we reach our goal of a sparkling pool?
    Is there anything different I should be doing rather than backwashing when the PSI gets too far above normal?
    We will be running a chlorine system this year as we also found out the salt system is not working properly and it will cost too much, quite frankly for a new salt cell this year. I managed last year with the methods here, but just don't know how to manage the current swamp.
    I really want to be able to let the kids swim this summer, but wondering if there is any hope.
    Thank you for your help. I appreciate any and all I can get!
    Mandy
    20,000 gallon fiberglass inground pool * Hayward sand filter and pump * Jandy Aquapure 1400 SWG * Jandy Aqualink Control System
    38,290
    Re: Pump Motor Fixed...Need Help
    No need to replace the sand, but Deep Cleaning your Sand Filter might be a good idea ... may want to do it again after you complete the ShockLevelAndMAINTAIN Process.
    Just follow the process and you should backwash when the pressure rises 20-25% over the clean pressure. tftestkits.net now carries some really nice gauges for the price of the crappy ones you will find locally.
    Read these to help you through:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Mar 2014
    Las Vegas
    288
    Your kids will be able to swim this year ( only if they knew how to swim last year ) Post up a set of test results and there will be plenty of help to point you in the right direction.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
