Thread: What way should I setup my jets for better circulation?
    Feb 2014
    dfw tx
    67
    I think they put in the skimmer to the wrong location.
    I changed all the eyes to the circulator eyeballs but the pressure is less on the eyeball opposite right corner of the skimmer so it falls out of sync with the other 2 and messes up the circulation causing my 2 dead zones.
    Next I tried keeping the other 2 as circulators and moving that one to point directly at the wall but it only eliminated 1 of the dead zones.
    Nothing is going into my skimmer since everything ends up in the dead zones now. I'm totally lost now. All of them used to be turned counterclockwise (when they were regular) and it caused a dead zone in the corner beside the skimmer.
    Arrow shows wind direction. Boxes are jets.
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    38,397
    Re: What way should I setup my jets for better circulation?
    If that is the direction of your typical wind, then the skimmer is certainly not ideal. What are the yellow areas? If those are the dead areas, I doubt there is much you are going to be able to do about it.
    Feb 2014
    dfw tx
    67
    yep yellow spots dead spots unfortunatly. they placed skimmer closest to the pump vs where it was needed unfortunatly.
    16k gallons
    1hp pump
    Built in 2000
    38,397
    I would point the bottom jet to the right as much as possible, the upper right one to the left as much as possible and the upper left slightly to the left to push things toward the skimmer.
    If by circulator eyeballs you mean the ones that rotate so the jet goes around in a circle to "improve" circulation then we don't recommend using them. First, they are just another thing that can break, and second they make it essentially impossible to solve the problem you are having right now. If you have/got return eyeballs that can be manually aimed you could aim them so that water circulation carried debris around to the skimmer.
