Results 1 to 10 of 10
Thread: Make any changes or leave as is?
    Jun 2010
    Toronto, ON. Canada
    230
    Here are my readings from this morning.
    FC - 5
    CYA - 60
    TA - 80
    PH - 7.4
    I put in my reading in pool calc and it says to add 202g by weight of washing soda/soda ash OR add 402g weight of borax.
    Should I up my PH to 7.5? Or do I need to do anything else?
    Also - what is washing soda? What is it sold as? I have only ever needed to use bleach or stabilizer. Never used washing soda or borax.
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    38,547
    Re: Make and changes or leave as is?
    Your pH is fine, you do not need to raise it. Are you setting the Targets in PoolMath and not just using the defaults?
    You need to keep your FC higher. 5ppm is the minimum for a CYA of 60ppm according to the FC/CYA Chart.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Shaf77 View Post
    http://www.troublefreepool.com/conte...pool-chemicals
    With CYA o 60, keep FC between 5 and 9, and never below 5.
    You're done SLAMing when:
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    He has a SWG. The FC/CYA chart for SWG pools shows a minimum of 3 and a target of 4. His FC of 5 is fine, but bumping it up a little won't hurt anything. He also does not need to add washing soda or borax, and likely will never need them. His pH will tend to drift up when the SWG is running. His CYA is also fine. We don't know his calcium hardness or his pool surface. Assuming the CH is right for his pool surface, he is right where he needs to be.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    38,547
    Ah missed the SWG ... then I would just keep the FC at 5ppm.
    Jun 2010
    Toronto, ON. Canada
    230
    Sorry for the delay.
    We have a vinyl pool. I guess Calcium hardness does not matter?
    Also, is washing soda? Same as baking soda? Or something else?
    38,547
    They are different.
    Jun 2010
    Toronto, ON. Canada
    230
    They are different.
    Thanks. Just out of curiosity what is washing soda sold as?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Jun 2010
    Toronto, ON. Canada
    230
    Re: Make any changes or leave as is?
    Thank you Richard320!
