Thread: painting itchy fiberglass filter
    Mar 2013
    Yucaipa CA
    87
    Hello,
    I have a 8+yr old Pentair DE filter that sits out in the sun. The outside of the filter has degraded because of the UV rays. If i touch it or rub up against i itch something terrible. I am building a shed over it soon but i want to paint it with something. What kind of paint would be the best without spending too much or harming the fiberglass undernieth.
    skeeter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: painting itchy fiberglass filter
    You can spray it with a clear coat finish for plastic or fiberglass that is rated for outdoor use.
    Love TFP? Become a
    TFP Supporter!
    38,305
    You know, I might consider spraying mine as well ... Arms are always covered in red spots when I am not careful.
    You can spray your arms with hairspray instead. Learned that tip right here!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    I nominate you to experiment and tell us what works.
    I've contemplated doing just that, myself. I'm just not sure what spray paint will stick.
