Thread: Lowering water level in pool with cartridge filter
    Jul 2013
    western new york
    62
    After receiving a lot of rain the water level in my inground pool is a high ( above the skimmer opening) . I know most folks with sand filters have a waste line they can pump off the excess. I happen to have a cartridge filter. I was thinking it would be easy to remove the drain plug located in the bottom of the filter chamber and plumb it with a valve and pvc pipe to a downspout from roof gutters nearby. Does anyone see a problem with lowering the water level this way?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Lowering water level in pool with cartridge filter
    Nope. Works well. Here's what I did (with pictures):
    http://www.troublefreepool.com/threa...lumbing-SOLVED
    Casey's Avatar
    SW PA
    10,461
    Good luck and let us know how it works out for you echo.
    P.S. Can you please add your location to your profile and your equipment to your signature.
    P.S.S. I just had to drain a lot of water off my pool this morning!
    Jul 2013
    western new york
    62
    Quote Originally Posted by Casey View Post
    Will do.. hoping to do this project this weekend. I was also thinking of just adjusting the deck jets to blast the water away from the pool and into the lawn. ( which really won't need more watering since the only time I need to lower water is after heavy rain (unless I overfill when adding water by accident)
    15k gal inground Viking fiberglass pool; Hayward Variable 1.5hp pump (Maxflo VS); Hayward swimclear 325 sg ft cartridge filter; Raypak 206A 199k btu nat gas heater; Aquabot Bravo robotic pool cleaner
    Mar 2011
    Houston, Texas
    413
    I didn't want to mess with the filter and PVC so I just drain with a submersible pump attached to a garden hose. I have a French drain in my back yard that connects to the city's storm sewer system and the water goes there. But there is the cost of the pump. IIRC it was about $50.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
