Thread: Believe I need a new pump. help
    Good Day everyone. It has been a long time since I posted on TFP and I can use some assistance.
    As of yesterday my current pump is starting to fail. When I power it on I hear a loud electrical buzz but no water flow. If I bang on it semi-gently it kicks in. I think the motor might be giving out.
    I am not certain what manufacturer/model this pump is but if I had to guess it is a hayward super pump from years and years ago. The previous owners of the house spray painted it all black. It is a single speed pump for certain. When I replaced the cover for the basket in the pump I purchased a hayward cover.
    My pool is a 21000 gallon 16x32 IG pool with a 250 Lb sand filter. I have one skimmer and one return. The pipes are 1 1/2 inch all the way around. The runs are relatively short. I think its about 10 feet from skimmer and maybe 30ish feet from return. I have no permanent high flow water features like waterfalls and spas. Sometimes I add a fountain directly to the return.
    Does this sound like a problem that ca be fixed easily and cheaply or should I just purchase a new pump? If I was to purchase a new pump what should I be looking for? Any recommendations?
    Thanks in Advance
    Brad
    22,200 Gallon Rectangle IG - Vinyl Liner w/ Jacuzzi Lazer Sand Filter
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Believe I need a new pump. help
    22,553
    Either that or the centrifugal switch contacts not making good connection. Or both.
    Thanks for the info!
