Thread: First Post, First Pool! Mystery Equipment
    Jun 2014
    Hendersonville, TN
    1
    First Post, First Pool...
    After much trial, even more error, and about 4 weeks of doing, I am almost swimming. Bought a house with a pool and there is some equipment I am not sure why is there.
    The main pump has a branch lone running to a smaller pump (recirculating all water through it), and from the smaller pump there is a line with a check valve that dives underground. There is also a spa blower with its own line diving underground right next to it. There is no spa though! When the check valve off the small pump is open, a very poorly located jet right next to my skimmer pushes water out, and it is bubbly/sudsy and pushes water away from the skimmer... When the valve is closed, I get head pressure inside the blower, and it leaks profusely. I cannot understand why this is set up this way. I have considered capping both the line to the blower and the direct line to the smaller pump, but am concerned this may cause too much pressure buildup in the system. But I don't know what else to do.
    Any suggestions as to what the heck I have in terms of setup as well as advice on how to stop the leak/sudsiness would be greatly appreciated!!!!
    27,000 gallon in ground pool; Age Unkown
    Hayward S245T sand filter
    Old Pentair Pump
    Hendersonville, TN
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: First Post, First Pool! Mystery Equipment
    Hi, welcome to TFP! Could you post some pictures of your pool equipment? It will help us answer your question more thoroughly.
    Love TFP? Become a
    TFP Supporter!
    22,548
    Welcome to TFP.
    It sounds like you have a cleaner pump. And maybe some bubblers, probably near the steps or on a tanning ledge.
    As Zea said, pics would help a lot.
