Thread: Jandy Valve Setup
    May 2014
    Crowley,LA
    14
    Jandy Valve Setup
    I have two 1.5" pipes going to my pump on from a bottom drain and another from a skimmer. I want to connect these to a three port jandy valve to be able to adjust suction to each. Can I put a suction on the "inlet" side of that valve? Meaning "T" is the valve, and the bottom of the "T" is labeled "inlet".
    1.5"➡️ T ⬅️1.5"
    2" Pump Suction
    Is this setup possible?
    So according to jandy the valve works opposite what I want.
    1.5"⬅️ T ➡️1.5"
    2" Outlet from pump or filter
    We'll that didn't publish right. The arrows on the line below the "T"s are suppose to be directly under the "T"s.
    Re: Jandy Valve Setup
    Yes, what you describe is totally fine and commonly done.
    May 2014
    Crowley,LA
    14
    Thank You.
