Thread: Finding the CYA sweet spot
    May 2012
    Redding, CA
    24
    Looking for advice on CYA level...
    CYA 30
    pH 7.5
    TA 130
    CH 260
    CC < 0.5
    OCLT 1 ppm
    I seem to be using a lot of bleach, FC to about 6 after dark, and by 3 or 4 pm next day FC is about 1 (Min should be 2 with my current CYA). Adding 5 ppm is nearly a gallon (112 oz) of 12.5%, which costs me about $4.50/day (more than I expected to be spending on bleach). Actually, many days I'm adding 1-2 ppm of bleach in the afternoon, to avoid dropping below the min, so my cost is more than calculated above.
    I know I'm fighting a lot of sun... Redding, CA (far Northern CA), full sun all day, and it's been 95-105F this past week or two. I'm concerned if I bump up to CYA 40 or 50, I'll need higher FC levels that just drop faster in full sun, i.e. I think I read somewhere here FC drops essentially with half-life kinetics. Will the extra CYA lengthen the half-life of FC? If so, I it would make sense to increase my CYA.
    Thanks!
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Finding the CYA sweet spot
    Yes, I'd bump it to 50. There seems to be a tipping point on CYA where all of a sudden the FC drop slows down drastically once your CYA threshold is crossed.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Quote Originally Posted by Smykowski View Post
    That's been my experience exactly. I was hoping to keep my CYA at 30 ppm but was losing 'bout 4 ppm of chlorine a day. After raising the level to 40, and after a few days, suddenly my chlorine loss slowed down significantly. We are now losing 1 - 2 ppm a day.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    May 2012
    Redding, CA
    24
    Thanks for the quick replies! I just added CYA to the sock, aiming for 40 ppm. I'll check it in about a week, and see how it goes, then bump up to 50 if I'm still losing too much FC.
    22,500 gal, IG plaster
    Pentair FNS Plus 36, DE filter
    3/4 HP WhisperFlo pump
    BBB believer, trying to be disciplined enough to make it work!
    24000 Gal in ground plaster pool. Pentair FNS 35 DE grid filter. 3/4 HP single speed pump.
    400 Gal Hot Spring spa. Fiberglass.
    22,553
    I run mine at about 50ppm or a little higher.
    The first thing to do is run a OCLT to make absolutely sure it's not organics eating the chlorine and then start raising the CYA until you're losing about 2ppm per day (24hrs).
