Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Foam vs sand?
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Foam vs sand?
    Breaking ground this weekend for my 16x48 pool! So level, foam board and tarp?
    Been searching for foam board vs sand for flooring. From my understanding foam replaces sand completely? I plan on leaving it up year round, no snow just rain here (northern California) . Does foam board hold up to elements well? I know it's more pricey but $100 more doesn't really bother me. I just want something that will last. I see most using 3/4" to 1". How many sheets for 16'? I read 8 I believe...
    I can't find this in my 94513 area
    http://m.homedepot.com/p/Owens-Corni...-37L/100320340
    What about:
    http://m.lowes.com/product?langId=-1...lue=4294858106
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Foam vs sand?
    Sand will wash away from underneath an intex pool with rain... There's nothing to contain it... Foam board should last a few years that's for sure, even longer if you take it down.... If your ground beneath the pool, is level, you shouldn't need anything else other than foam.... It really does make it nice underfoot...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2014
    206
    Re: Foam vs sand?
    Thank thank you found 3/4" too just scary it's water "resistant " which is y I turn to the experienced pool pros!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Re: Foam vs sand?
    Anyone else using the above from Lowes?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Re: Foam vs sand?
    Pink stuff is the best but expensive. I think just about everyone here would give you a no on the white. White stuff does crumble but will work. I used white in my current pool but only because I will be ripping it out in another year and to add a hopper as my girls become better swimmers, then we will go pink! Hope that helps
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    Jun 2014
    206
    Re: Foam vs sand?
    Thank you, just can't find white around here =(
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    May 2014
    LA, USA
    16
    Re: Foam vs sand?
    I used the 3/4" blue extruded polystyrene as did many others on TFP. The expanded type would likely be too soft.
    AG-Intex Ultra Frame 32 ft x 16 ft x 52 in, Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skim Above Ground Pool Skimmer Kit
    Intex 2650 GPH Sand Filter Pump & Salt Water System CS20110
    3/4" Extruded Polystyrene Foam Board Insulation, Gorilla Floor Padding
    Borated sparkle added
    Jun 2014
    206
    Re: Foam vs sand?
    They have that at HD or Lowes?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    May 2014
    LA, USA
    16
    Re: Foam vs sand?
    Jun 2014
    206
    Re: Foam vs sand?
    Dang it, none around me! Lol
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Re: Foam vs sand?
    And it's begun!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2013
    Manitoba, Canada
    153
    Re: Foam vs sand?
    Anyone ever use the 1/4" fanfold foam? Comes in bundles 4'x50' and unfolds. Designed to put up the house side before installing siding. http://www.menards.com/main/building...358-c-5778.htm
    http://www.astronomyboy.com/tm_image...cor_bundle.jpg
    Jun 2014
    marshfield, ma
    9
    Re: Foam vs sand?
    I wish I was on this site before I set up my pool
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Foam vs sand?
    Quote Originally Posted by xanadu View Post
    That thickness would be crushed completely flat underneath the weight of the water unfortunately.... You wouldn't get any real benefit from it....
    Jun 2014
    206
    Re: Foam vs sand?
    I just don't get why no stores carry extruded foam around me
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Foam vs sand?
    Quote Originally Posted by Slammed01 View Post
    Sent from my SPH-L710 using Tapatalk
    I found it at Hawthorne CA.... http://www.lowes.com/pd_15358-1278-3...7C1&facetInfo=
    Is that anywhere near you.... My geography is not real good considering I'm half a planet away....
    Jun 2014
    206
    Re: Foam vs sand?
    No, I'm in Brentwood, Ca.... san Francisco Bay Area. I greatly appreciate it though =(
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Re: Foam vs sand?
    So the place by me shows they carry "fill sand or mortor sand" (maybe they mean Mortar? LOL)
    •Sand: Fill Sand and Mortor Sand
    Will any of those work for my sand base? Maybe 3 yards or so? I'm guessing mortar...
    also found a cool lil calculator
    Round Shapes
    Depth (Inches) Diameter (Feet)
    3" 18'
    Tons Required: 3.19994
    Jun 2014
    Uxbridge Ontario
    56
    Re: Foam vs sand?
    Brick Sand, probably the same as mortar sand.
    That is what I used.
    My soil, mostly clay was already pretty level though and I used about a tonne. (approx 3/4 yard) for a 14' pool.
    Just for a good skim coat on the top to perfect it. Leveled it out, wet it down, and tamped it down with a hand tamper until it was well compacted.
    We just had the craziest driving rains here last night and I only had about 6-8 inches of water in the pool and as far as I can tell the sand didn't go anywhere... even the bits around the pool where the pool wasn't covering it.
    You HAVE to make sure you tamp it down though, and I would still use a ground sheet too.
    I just didn't have anywhere to keep the foam over the winter, and I didn't want to have to buy more every year or leave it out in the yard all winter either.
  20. Back To Top    #20
    Jun 2014
    206
    Re: Foam vs sand?
    So they said "fill sand" is what everyone is using at around $35/yard. 3 yards and delivery is $135. Figure If I have extra I can do a pacer walkway.
    Anyone use fill sand? I talked to 2 places and both said fill. Mason sand was $65.00/yard
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
