Thread: Had to completely refill pool and have questions
    Jun 2014
    Pekin, IL
    2
    Hey0!
    I am a new member. A buddy of mine suggested this site and I'm in!
    I had to completely refill my pool after it was repaired from tornado damage. I refilled with water from the hose, purchased my T100 test kit and tested the water twice.
    My results are:
    FC=3 good
    PH=7.5 good
    TA=370 high
    CH=375 high
    CYA=less than 20 low
    All I have done is add bleach and a little leftover Cyanuric Acid from last year. I understand I need to get the CYA up and will do that via the sock method.
    From what I read, it is OK to have the higher TA and CH, but if I lower the TA via muriatic acid and aeration over time while not letting my PH drop too low, it will also lower the CH too?
    Is this right and the best course of action?
    Vinyl Above Ground 13x25 Splash Superpool /10600 Gallons / Sand Filter / Hayward 1.5hp Power-Flo LX Pump
    May 2013
    Bay City, Michigan
    283
    Re: Had to completely refill pool and have questions
    Quote Originally Posted by nickboyer View Post
    Adding muratic acid will lower your TA and PH. Aeration will increase your PH only. Neither of them will effect your CH. Only adding water with less CH will lower your total CH. That would be fill water or rain water, unless of course your fill water is higher than 375).
    Lowering TA is a process of adding muratic acid to lower PH and TA, then aerating to raise PH up. Then adding more acid to lower ph and ta again. The acid lowers both, and the airation raises PH only.
    Given you have a vinyl pool, I don't THINK your in danger of anything bad happening with those levels, but really I'm not 100% sure so I hope someone else can comment on this part.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Scott gave good info. Sounds like you got it under control. CH only goes away with RO (Reverse Osmosis (expensive)) or adding water that has lower CH.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Welcome, Nick
    You understand the TA lowering. Use the search box for "aerator" and look for the icon. That means pictures. It'll give you some aerator ideas. Sadly, that doesn't work on CH.
    If the CH is 375 straight out of the tap, you've got your work cut out for you! If you get any rain in the summer, try to grab as much as you can to fill your pool. Drain down a little before the rain fall, aim a raingutter downspout into the pool, whatever.
    Jun 2014
    Pekin, IL
    2
    Thanks Guys!
    My CH actually is 375 straight from the tap. Gotta love Pekin water! The raingutter downspout is a great idea!
    Thanks to everyone here at TFP I am actually excited about the pool this year! Plus, I geeked out a little over the chemistry set that is the TFP T100 test!
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    And I thought I was the only one....
    Welcome!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
