Thread: Sequence and timing of chemicals important
    kmwest3302's Avatar
    Jun 2014
    Danville, IN
    13
    If addressing multiple issues, do you need to follow a certain order to add chemicals? Is 30 minutes between adding different chemicals sufficient? In other words, if pH is low and FC is low, does it matter which to attack first? Thanks
    25,000 gal IG Vinyl
    Tagelus TA-60 Sand 60 gpm
    1 HP Whisperflo Single Speed
    Built April 2004
    Using TF-100 Test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Sequence and timing of chemicals important
    Ph first......add FC 30 minutes later. TA is always last.
