Thread: Lots of questions before my build
    Jun 2014
    Brandenburg ky
    1
    Ok first off I have a customer wanting a outdoor kitchen with a build in ref. and possibly a roll out trash can. I plan on framing it out of steel studs. I was planning on using 1/2" cement board on walls and then either stone tile or porcelain wall tile available at lowes. I was also considering cement board for countertop and granite tile or possibly travertine tile or porcelain tile on top. I was considering wrapping the top with rubber over cement board to be safe. I don't see where anyone else is really waterproofing the countertops if they are being tiled. So this is why I am mentioning rubber. Has anyone tried this? And what about the walls? Will just cement board , thin set and tile be good enough to keep from water seeping threw? Any other tips anyone could throw my way would be appreciated. Thanks in advance.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Lots of questions before my build
    You could use a kerdi membrane under the tile for waterproofing. You see it used in tile showers quite a bit.
    Love TFP? Become a
    TFP Supporter!
    Killer95Stang's Avatar
    Sunny SoCal
    591
    If you are worried about the water, just coat the whole thing in RedGuard or Hydroban before you tile. Like said above, treat it like a shower and you should be good to go. John Bridge Tile forums will have a lot of info on waterproofing if you have any questions.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
