Thread: I think I'm through SLAMing..what's next?
    May 2014
    Burlington, NC
    45
    I think I am through SLAMing since last Wednesday. Current levels are:
    FC = 1.5 ppm
    CC = .5 ppm
    pH = 7.2
    TA = 70
    CYA = 40
    Will do an FC overnight loss test tonight to be sure but believe it will pass (thanks TFTestKits for the quick delivery of more reagents!). Pool is very clear all the way to deep end and can see bottom drain well.
    So now what do I do? I just added liquid chlorine to bring it up to 5 ppm not to SHOCK level again. Am I now at the "comfortable" daily maintenance schedule of checking chlorine and pH every day? Just want to be sure I'm doing it right and still need hand holding at this level.
    Thanks for all the help!
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    38,540
    Re: I think I'm through SLAMing..what's next?
    How could you be SLAMing with FC levels that low? The answer is you can't. That is below the minimum for your CYA level.
    Raise the FC back to SLAM level for the OCLT. If you pass, never let the FC get that low unless you want to SLAM again.
