Thread: discrepancy with CH test instructions
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Sorry this is duplicate if u have been reading my thread "I'm on board; Want to ditch pool guy." I figured maybe thus should be a separate thread. Here is the post :
    Kiss4afrog, yes, I am pretty sure I did the test correctly per the TF100 instructions. I even verified on the Extended Test Kit Directions by Jason Lion at this site that the volume was 10 ml (as stated in the TF100 instructions) vs. the 25 ml sample called for in the Extended Test Kit Directions. I used a 10 ml sample of water and followed the directions in the TF100, and then multiplied by 25. But, now you have me second guessing.
    I just checked the TF100 website, and it calls for a 25 ml sample to be used. The laminated card in my kit calls for 10 ml sample. At the Extended Test Kit Directions, it reads:
    If you expect that your CH level is extremely high, you can do the test so that each drop is 25, instead of 10, to speed up the process and save on reagent usage. Use 10 ml of pool water, 10 drops of R-0010, 3 drops of R-0011L, and multiply the number of drops of R-0012 by 25 to get your CH level.
    I don't know why TFTestkits has differing information on the laminated card with the TF100 kit vs. what I read at TFTestkits.net with regards to the sample size for the CH.
    Is this any reason for me to retest and use the 25 ml sample? Using the 10 ml sample this AM, my level was 900. This is high, but much better than what I started at which was 1500. Per Pool Calculator, if I manage adjust my pH & TA, a CH of 900 can be managed and my water balanced per the CSI.
    19k gal IG plaster, built '70s, probably resurfaced in '80s-'90s; Blue Haven Hayward filter C4520BHMB (Filbur FC-1275 cartridges); Hayward MaxFlo sp2302 VSP 1.5hp; 6 solar panels 288. sq. ft. total (142"x47.5" ea.) on 1 story hm; Pentair Compool LX220 Solar Controller; FlowVis flow meter; Maytronics Dolphin S200; AG 300 gal AquaTerra spa; TF-100 & Speedstir; gone: Pentair Challenger 3/4 HP 1 speed; Polaris 280
    38,301
    Re: discrepancy with CH test instructions
    10ml uses less reagent and is accurate enough. Sounds like Dave needs to update the website to make that change.
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Tx Jblizzle. That's why I thought the 10 ml sample would be better to use as it saves on reagent, but yes I did wonder if the 25 ml sample would yield differing results.
    38,301
    I have found them to match pretty well, but I am only around 300.
