Thread: Control Panel reading 32
    Jun 2014
    Thompson, ND
    33
    My hot tub is warm, its set at 99 right now and that feels about right. The problem is, the panel displays 32 degrees. I can adjust the temp up and down, but it says the temp is 32. Does anybody have any experience with this issue? I accidentally ran it without water overnight...I might have damaged some component. Everything else seems to be working fine.
    21,000 gal AG 30 foot round pool. Sand Filter. 1.5 hp pump.
    360 gallon 2015 relay hot springs hot tub
    North Dakota
    38,475
    Re: Control Panel reading 32
    That is close to the conversion between degrees C and F ... any chance the display got changed?
    Jun 2014
    Thompson, ND
    33
    I checked that. It's F.
    Jun 2014
    Thompson, ND
    33
    Now the temp is reading 107-109 and the spa is set on 95. Why would it be overheating the water?
    North Dakota
