Re: Future pool location photo
I believe testing and adding bleach less frequently could actually cause you to use even more bleach in the long run as it would extend the length of your SLAM. The more frequently you test and dose, when needed, the faster the SLAM will go, using less bleach overall. Sometimes even as frequently as every half hour when chlorine consumption is really high. As your consumption slows you can slow your testing, but make sure you always Maintain SLAM levels until you have a clear pool, .5 or less CC and pass OCLT.
I'm sure someone more experienced than me will come along to confirm this.
Is it better to test less frequently during the day to conserve bleach when I don't have CYA readings yet? Or do I just continue to dose as frequently as every hour?
