Thread: Reason why I had air in my AG plumbing
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    Intex Deluxe Wall Mounted Skimmer Hose Adaptor, connected to pool's strainer connector outlet to pump and filter
    16' x 48" 5000 gal. Intex Ultra Frame AG Pool, Los Angeles, CA
    Hayward Full-Flow Cartridge Filter System with 2 Speed Power-Flo Matrix Pump,
    Intex SWG, Intex Wall Mount Surface Skimmer, Solar cover & Solar Roller,
    Confer Plastics A-Frame 7200 Adjustable Roll-Guard Safety Ladder,
    Kokido SkoobaMax Vac, Custom Canine entry & exit ramps,
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: Reason why I had air in my AG plumbing
    ah ha! Thats gotta be it!
    Divin Dave,
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Wow, there's a lot of stuff in there...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
