Thread: Friends Pool Numbers
    wjr75's Avatar
    Jun 2013
    IL
    836
    Trying to help a friend. His TA and PH are out of wack. TF-100 Test numbers
    FC=1ppm
    CC=0
    CYA=70
    CH=100
    ph=below 6.8
    TA=Was pink after adding the two drops R0007 and 5 drops of R-0008 does this mean less than 10?
    How do I tackle the TA and PH? The pool is 13000gallon Above ground liner non SWG. Should I bring up the TA with baking soda using 183oz indicated in pool math than bring the PH up with borax? Never had to deal with TA and PH this bad.
    Thanks!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Friends Pool Numbers
    I would try seesawing.
    First add Baking soda to get to 50
    Then test and add borax to get to 7.2
    Recheck pH and TA and adjust pH again, since the first borax might not have been enough.
    And so on, bringing things up by degrees. Poolmath isn't good for huge adjustments so work up.
    Feb 2012
    Phoenix, AZ
    728
    Agreed with above advice. And once those two are in order, don't forget to get the FC up! CYA is already pretty high, so chlorine tabs are not ideal
    wjr75's Avatar
    Jun 2013
    IL
    836
    Thanks Guys!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    A "friend" huh?. We've heard that before! Get him fixed up.
    wjr75's Avatar
    Jun 2013
    IL
    836
    LoL! I can assure you it isn't my pool I'm TFPC perfect!
