Results 1 to 20 of 20
Thread: PSI gauge.
    Jul 2011
    Corinth, NY
    76
    PSI gauge.
    I have my pool filled and just started the filter. The PSI gauge is pinned past 60. Anyone know why that would be?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: PSI gauge.
    A bad gauge. Does it go to zero when the pump shuts off?
    Mark
    Jul 2011
    Corinth, NY
    76
    Re: PSI gauge.
    No it doesn't go to zero when the pump is shut off. It goes to 50.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: PSI gauge.
    Replace the gauge.
    Mark
    Re: PSI gauge.
    Here ya go...... TFtestkit.net ... Great products...OUTSTANDING customer experience.
    Sami
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Jul 2011
    Corinth, NY
    76
    Re: PSI gauge.
    Okay thanks. Can I run the filter though for now?
    38,251
    Re: PSI gauge.
    Of course, you just will not know when you need to clean the filter without a gauge.
    Jul 2011
    Corinth, NY
    76
    Re: PSI gauge.
    If the gauge wasn't bad, what would make the gauge go that high?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: PSI gauge.
    +1, the gauge is shot. I just ordered one from the same place the test kits come from (TF100). Best part is it's liquid filled. Rain, moisture getting in there is what usually causes the most damage to them. It was about $11
    It also helps support this site.
    http://tftestkits.net/Flow-Meters-and-psi-Gauges-c12/
    Solar Blanket, Well Water, Borax Added. 68
    38,251
    Re: PSI gauge.
    Well it is not possible for the pump to generate that amount of pressure ... so nothing made it read that high. It just broke.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Re: PSI gauge.
    Quote Originally Posted by kiss4afrog View Post
    +1, the gauge is shot. I just ordered one from the same place the test kits come from. Best part is it's liquid filled. Rain, moisture getting in there is what usually causes the most damage to them. It was about $11
    I received mine today and just switched it out. I'm very impressed with the look and quality of this gauge. Having .5 psi increments is great.
    Jul 2011
    Corinth, NY
    76
    Re: PSI gauge.
    $6.00 on ebay.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: PSI gauge.
    Quote Originally Posted by mkdsk101 View Post
    $6.00 on ebay.
    Cheaper gauge off of ebay ... $5 saved .... Trouble free, algae free, clear pool thanks to this site .... PRICELESS
    I know i bought mine from here and am happy to buy all of my stuff here instead of trying to save a few dollars!
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: PSI gauge.
    I've had my filter gauge that came with my new Hayward multiport for just over a month. It's a 0-60 psi, not liquid filled. It's had moisture inside it since almost immediately. I have that one and a much better Wika gauge (not filled either though, but it has a vent/seal valve). I'll be putting the Wika gauge on shortly. You always get what you pay for with measuring equipment.
    Isolated Spa - 345 Gallons
    Jul 2011
    Corinth, NY
    76
    Re: PSI gauge.
    We can buy right from this web site?
    38,251
    Re: PSI gauge.
    tftestkits.net is owned and operated by Dave who also owns this forum.
    One way to show appreciation for the forum is to patronize his business, the other is to Become a TFP Supporter. You will note that there is no advertising on this forum ... to keep it running, we need supporters which funds the maintenance and upgrades of this forum.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: PSI gauge.
    It's almost like a Pool Store, everything you need in one place (just more user friendly)
    Jul 2011
    Corinth, NY
    76
    Re: PSI gauge.
    Thank you. I didn't know that..
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PSI gauge.
    Thank you for the compliment, but we are different in one extremely important way.
    We educate people here, and the is the core of what we do. It empowers people to truly be in control.
    Essential Links:
  20. Back To Top    #20
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: PSI gauge.
    Quote Originally Posted by DaneCE View Post
    Me too, really nice gauge, good quality. Purchased a cheap one last year that I've had to take the plastic cover off and dry out a couple times now. That will get moved to the indoor spa !!
