Thread: How to make my pump pump harder
    Jun 2014
    Carlsbad/NM
    2
    I have a Intex® Krystal Clear Sand Filter - 16" pump for my Intex 32 ft. x 16 ft. x 52 in. Rectangular Ultra Frame Pool. I purchased a Hayward AquaRay Automatic Pool Cleaner. It will run for a short period of time and then stop pumping. I take it off and the pump is just barely sucking. How can I improve the amount of suction into the pump. I checked for blockage and found nothing.
    38,271
    Re: How to make my pump pump harder
    Welcome to TFP!!!
    When was the last time you cleaned the filter? You can not make a pump move more water without lower the resistance to flow.
    Could be that your pump is just too weak to run that cleaner (although admittedly I know little about the Intex pump/filters).
    Apr 2013
    North OKC Area
    300
    Does it work good after backwashing the filter?
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    Jun 2014
    Carlsbad/NM
    2
    We cleaned it before we put it on the pool this year. How do I lower the resistance to flow?
    Haven't tried backwashing the filter yet. Will try that tonight.
    38,271
    Quote Originally Posted by Katslate View Post
    Clean the filter. Install larger pipes. Make sure no valves are partially closed and there is no clog.
    You need to clean the filter when the pressure rises 20-25% over the clean pressure.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    On the suction side, where the vacuum hose plugs into pool wall, unscrew the blue adapter and check the plastic grid behind it. Many Many Many times it will be full of bugs, leaves, algae, funk and it will dramatically reduce how much fluid you can move. When I got a real pump and filter for my pool I ended up just cutting that grid out of there. However with that grid cut out I never run my vacuum without a Leaf catcher between the vacuum and the pool wall, Good Luck.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
