Thread: Question about lowering PH without messing with TA
    duckcmmndr's Avatar
    May 2014
    Arkansas
    64
    Ok....this is just a theoretical question at this point.
    I have spent the last couple of weeks going through the "raise PH through aeration, lower PH and TA by adding acid" process. I got my TA to 80 which is where it needs to be. My PH was 7.4 this morning and I am running my fountain today to bring the PH back up to the 7.6-7.8 range where it should be.
    Here is where the "theoretical" part comes in. I will assume that the PH may climb above the acceptable range as kids play in the pool and aerate it or if I run the fountain to help keep the temp of the water down once the summer sun starts to warm things up. I don't know that this will happen, but based off of my limited (3 weeks) experience with this pool, it appears that the PH is prone to climb easily with aeration and I have read that aeration is a great way to help keep the temp of the water down in the hot summer months. Right now my water is 82 and I have only seen it climb to 86 prior to the last cool rain we had that dropped it back.
    Assuming that does happen, is there a way to lower the PH without effecting the TA?
    Also, now that I have the TA in the upper end of the acceptable range will the PH be more resistant to change? (it was at 130 at it's highest)
    Just thinking ahead and trying to stay on top of things.
    Intex Ultra Frame 18 X 48" AG (6,420 Gallons), Intex 16" .95HP Sand Filter SWG System (2650 GPH), Hayward thru wall Skimmer, Hard plumbed with fountain, Taylor K-2006/SpeedStir/SampleSizer
    38,237
    Re: Question about lowering PH without messing with TA
    Adding acid always will affect the TA. If it gets too low, just add a little baking soda which has a VERY small affect on the pH.
    With a SWG, I would try to get it down to 60-70ppm myself to slow the pH rise due to the SWG.
    duckcmmndr's Avatar
    May 2014
    Arkansas
    64
    Thanks....I don't think it will be too difficult to get in the 60-70 range on TA, I just stopped the process after I finally hit the upper end of the recommended range. A couple of days of lowering PH after it has gotten too high should do it. I have baking soda, so I will give that a try once I get to that point.
    Right now I am just enjoying the fact that the water is sparkling and crystal clear. It's as close to balanced as anyone could hope for, thanks entirely in part to the great information that I have gotten from this site. Every ABP that I have had prior to this one ended up be a green frog pond in a matter of weeks.
    38,237
    WOW!!! that is a sparkly pool
