Thread: trouble with cloudy pool
    Jun 2014
    jacksonville,nc
    1
    hello
    i have a 1500 gallon oval above ground pool with a Hayward PowerFlo LX 1.0hp pump and a sand filter. pool pump broke over the winter pool so pool was filled with algae, fix problem. vacuumed pool put 3 lbs of shock and algaecide waited 24 hours,pool was cloudy vacuumed again put 2 lbs shock still cloudy. put clarifier in twice pool is still cloudy. what can i do everything is good except ph is a little high. any suggestions.
    38,515
    Re: trouble with cloudy pool
    Welcome to TFP!!!
    We do not recommend the use of shock powders, algaecides, or clarifiers.
    We recommend following the ShockLevelAndMAINTAIN Process making use of one of the Recommended Test Kits.
    Please define "everything is good". We like numbers. Please post up your test results and what kit was used to get them.
