At my wits end - pool won't clear
Jul 25, 2011
98
Huntsville, AL
For the last 4 weeks I've been battling my pool. I know I've lost 3 weeks due to my stupidity of not getting all the leaves and debris out of my deep end. Everything I was able to scoop out is out. I slammed my pool starting Friday and it went from milky to less green, to the color it is in the pictures. It is NOT getting clearer daily. It has been stuck looking like this since Monday. What am I missing?
Make sure you have gotten out all of the solid debris in the pool you possibly can. Piles of leaves on the bottom can leave you stuck at just this point.
The other two issues are chemistry and filtering. The color of the water suggests a problem with the filter, but we need more information to be sure. It would help if you could post a complete set of water test results, and describe how the filter has been behaving, does the pressure go up steadily, have you been cleaning/backwashing the filter?
Make sure you have gotten out all of the solid debris in the pool you possibly can. Piles on leaves on the bottom can leave you stuck at just this point.
I'll post complete test results soon as I get home. Pressure goes up steadily. Normal pressure is 18. I usually backwash at 23. I've been backwashing/rinsing daily.
sent from my Verizon Galaxy S3 on PPC.
A few years back I replaced my laterals and pipe vertical pipe in the tank. Could a bad o-ring or spider gasket cause my issue? I've never replaced either. I'm going to pull the valve apart and take pictures.
A bad spider gasket could let water bypass the filter. However if that was happening your filter pressure would not go up from 18 to 23, so the multi-port valve is unlikely to be involved in the problem.
You mentioned "mounds of leaves at the bottom", if there are lots of leave in the pool that is almost certainly the issue.
The backwash port had a slight drip from it the last time I took the backwash hose off. Should I see if it still leaks. Here is what the gasket looked like yesterday.
My test came back
13.5 FC
7.2 PH
80 TA
50 CH
50 CYA
Keep your SLAM level up and brush and sweep your pool.
JasonLion,
What information can I provide to help determine whether or not the filter is the issue? Should I by some DE and toss it in the skimmer to see if it comes out the returns.
I'm not sure what to do. This quote worries me.
While SLAMing, the appearance of the water should improve each day, though perhaps only by a little. If you fail to see any improvement you might have a problem with your filter, or have a higher CYA level than you think, or bad circulation, or have some other more complex problem.
It is like I've hit a wall. I literally have seen no improvement in 3 days.
You have seen no improvement but is the pressure still rising in the filter? You mentioned the pressure is rising steadily and you've been backwashing daily.
If that's the case it looks to me like the filter is working and it's just taking that annoying time that it takes at the end of a SLAM for the filter to finish filtering everything out.
That's my $.02 but it might be only worth what you paid for it! lol
Can I have a leak in the filter that is causing water to go by unfiltered which is slowing down the process? Maybe I just need to hunker down more and be patient. I wasted 3 weeks with leaves in my mounds of leaves in my pool. Perhaps I'm impatient because of that. It has been 5 days I think since I got the leaves out.
That is quite a bit of improvement. Hang in there and keep slamming. I thought I had all the leaves out of mine until it cleared up enough to see the bottom and I still had a small pile in the center of the pool. You may find something similar in your case as the pool clears. You are doing a great job!
