Results 1 to 9 of 9
Thread: XPS not available can I use Polyisocyanurate
    Jun 2014
    Dave's Not Here
    2
    Question XPS not available can I use Polyisocyanurate
    XPS not available in my area Sacramento CA lots of building going on.... can I use Polyisocyanurate instead or should I use EPS.... I am putting up a Intex pro series 14x42 on a concrete pad... I have read that some here have used it.... Anyone have an problems/damage to the pool caused by using Polyi?
    Thanks for you input...
    Dave
    38,275
    Re: XPS not available can I use Polyisocyanurate
    Welcome to TFP!!!
    I have no idea what you are talking about, but someone should be able to help.
    I just wanted to ask that you update you profile with a useful location. If you are willing to state it in your first post, I am not sure why you would not put it in your profile so we do not have to ask in every thread you create.
    30,419
    I, too, have no idea what you are talking about. Putting your correct state and city in your sig is quite helpful.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,989
    I believe he's talking about foam board. Extruded Polystyrene is hard to find in California for some reason. The yellowish foil backed foamboard is not.
    Sorry... even though I understand the question, I don't have an answer.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    He is talking about rigid foam board. Probably questioning if he can use it under the AGP
    ***Went to get a drink before posting and Richard beat me to the punch***
    Support the site
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Crew Dawg Dave,
    Can you order XPS online or through a local Home Depot or Lowes or what ever stores you have there? Maybe they can bring it in from another store for you?
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Oh, also, when I was researching for my own use of XPS, I called a sheet insulation manufacturer. I'm not sure what Polyisocyanurate is but, if it is regular insulation, they told me that it would be crushed by the weight of the pool. The 3/4" I used was all that was available in Florida. I guess we don't get cold enough here to warrant the thicker stuff that others on here use.
    Angie M.
    Jun 2014
    Dave's Not Here
    2
    Thanks for the info Taterfink... I needed to get the pool up and running (for medical reasons) So I went with the 1 inch Polyi foam board. It is similar to XPS that you used. There is a bit of a building boom going on (again!) so XPS is not available in Lowes or Home Despots. We will see how the polyi holds up. I did take some pics and when I download them I will try to post some. Thanks again for your help.
    Dave
    Intex ProSeries 14' X 42" Metal Frame AGP, Vinyl, 3300 gal. factory cartridge filter and pump. (Soon to be upgraded) base is 1 inch Polyi foam board over concrete. Red wood deck and Soon to arrive Confer Plastics Curve Base In-Pool Steps
    West coast... Nor CA.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Dave,
    you are most welcome. I'm glad that I could be of help.
    Can't wait to see you pictures!
    Angie
    Angie M.
