Thread: 1 1/2" or 2" Pipe
    PPrince's Avatar
    Jul 2013
    North Coast of Ohio
    55
    1 1/2" or 2" Pipe
    Greetings,
    Working on setting up the pool and have flexible hoses currently but would like to switch to rigid pipe. The pool is not that big but wondering if I should use 1 1/2 or 2 inch sized pipe. I looked through the hydraulics 101 post but I may be too dense to decipher the information. Lol.
    Schedule 40?
    Thanks.
    Paul
    8000 gal 18' x 48" AG steel wall pool, 1 HP Hayward Perflex DE filter, SWG, Jandy Lite 2 Heater - 175K BTU
    38,248
    Re: 1 1/2" or 2" Pipe
    With your smaller pool/pump, 1.5" would be fine. You might get a little more flow with 2", but not sure it would be worth the added cost.
    My pool runs fine on a single 1.5" suction line.
    Yes, schedule 40.
    I recommend 2" all the time because it really doesn't cost much more so it tends to be worth it even when it only makes a small difference.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I'm using 2 inch as the intex fittings that came with my pool are 2 inch... My pool is tiny compared to most...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    PPrince's Avatar
    Jul 2013
    North Coast of Ohio
    55
    Thanks for the advice. I will probably go with the 2".
    Paul
