Results 1 to 10 of 10
Thread: Leveling ground for pool
    Apr 2014
    Florida
    3
    Hello. I have a question about leveling the ground for the pool. The pool will be on a small slope. I was planning on digging the high end out to match the low, but this is not possible due to the sprinkler system being in the way. I'm going to have to add dirt to bring up the low side. My plan was to build a small retaining wall on the low end and filling it with dirt then compacting it down. I will only need about 4 inches of fill. What do you guys think about this or recommend I should do?
    Thanks.
    May 2012
    Montville NJ
    545
    Re: Leveling ground for pool
    it is always better to cut than to fill. There is a lot of weight on that ground, and any fill needs to be compacted and compacted WELL.
    However, if you must, you must. 4" is not too bad. Build a GOOD retaining wall, anchor it well, and compact the fill with a good compactor (at least a vibratory plate) in multiple lifts.
    A full pool is a lot of weight, an it is not particulary rigid. If that slope gets wet, and moves a bit, the whole pool will begin to follow.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2013
    SW OKC
    29
    Is there any way to split the diff., dig 2", fill 2". Might save you from having to buy dirt.
    18x48 Intex Ultra Frame, 6,423gal, 1500gph Cartridge, SWG, Setup June 2013.
    30,431
    I would not use the dirt you dig up for refill. You should be able to get a pick-up load of "screenings" at a quarry. It is easily spread with a rake and very easy to compacy (it will not need much).
    The dirt might work but it might cause you more headache than it is worth.
    (Of course, without a pick up available, you might even consider a truck load if you have a place to dump it in your yard. I live on acreage and find I use "screenings" for several projects. Didn't mean to confuse the issue....this is really unrelated.)
    Casey's Avatar
    SW PA
    10,457
    Agree with Dave on using screenings or crush n run. Its very easily compacted with the plate compactor. You will be better off using it than dirt.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Crush and run is the best stuff... It is also much sturdier than dirt...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    30,431
    Crusher run is somewhat difficult to rake easily and make level.....much more so than screenings. Screenings are subject to wash from rainfall if they are exposed but this is going underneath a pool.
    If you use more than about 2" thickness of either product, it would be good practice to create a small "retaining wall" out of whatever is handy and looks decent right at the edge of the pool where the substrate is exposed (albeit just slightly) to erosion.
    The workabilty of "screenings' or "fines" gives it a big advantage over crusher run, IMO
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Is it a good idea to even set the pool on top of the irrigation system?
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    When I was digging I hit some old sprinkler lines. I hacked them off since I no longer have the system connected. You will need to cap the pipes off or re-locate the sprinkler heads. Don't need to water under a pool!
    21' Round 48" Deep Doughboy Timberline III, 9100 Gallons
    Using 80lb Media Master sand filter and 1HP Powerpak II.
    May 2012
    Montville NJ
    545
    I agree - Crusher Run (also known as Quarry Process or QP depending on where you live) is the same as screening, except it has up to 3/4 stone in it as well. Screenings are more of the consistency of sharp sand. I love QP - if I am working with a machine (loader, dozer, etc). If I am working with hand tools, QP is a pain in the rear - use screening.
    Both have a very flat proctor curve. A soil has a single moisture content where it will reach maximum compaction. Go above or below that and you can never compact it to 100% density. Some soils are very picky. Go 1 or 2 percent above or below the optimum moisture content and you will never reach more than an unsatisfactory compaction level. QP and crusher run are very forgiving, you can be pretty far above or below the optimum moisture and still hit 95% or more of the ultimate compaction.
    -dave
    Zodiac Wahoo
